squeeforever
squeeforever's Avatar
05.15.2005, 11:40 AM
as for your shocks you might want to consider making some solid struts. i had the same problem and simply got some round aluminum stock and cut it to the appropriate length and did a little grinding on the ends and drilled some holes to mount them.
i can honestly say that i NEVER rolled it over. all you have to do is dont make it TO low just 2 inches off the ground will do.
