MetalMan
MetalMan's Avatar
10.23.2006, 10:22 PM
You should see if Mike would be able to make it just for testing. It would certainly be an alternative to the slipperential, with less weight and complexity.
At one point I had the idea to make a slipper-diff in place of the center diff. It would have a custom spur gear mount (in place of the Hyper 7/8 spur gear) that would have a slipper clutch built into the back of it. Some time I should attempt to draw it up in Solidworks.
