Originally Posted by jhautz
so really it just needs a lipo charger that has a 3.7v cut off on the charge vs the 4.2 a lipo would use.
Are there any lipo chargers that have an adjustable cut off voltage? That lipodapter seems really confusing.
The cutoff voltage for M1's isn't 3.7 its 3.6 volts per cell. The LipoDapter is really easy to use and has automatically cutoff at 95% capacity every time I've used it. The Xtrema is an example of a charger that has the capability to charge Lipo's and M1 cells. It runs around $190. I already have a NiMh charger that I can charge up to 7.5 AMPS so I went with the LipoDapter. There really isn't anything fancy about the LipoDapter, its straight forward and easy to use.
