Originally Posted by E-Maxx King
2300mah? About the BEC on the EVX, could thid be done? So you can drop in your freshly charged packs. My GP4300 7 cells charge up about 18 volts! Cause wont it studder till it drops to 16.8 volts?
An external BEC can be used w/ any ESC as long as the battery voltage is above the BEC output voltage. The EVX would mostly benefit from reduced heat. I'm not sure what you are saying about the stutter tho.:032:
Most NIMH cells charge to ~1.45V/cell right off the charger than quickly drop. I have an 8 cell pack that charges to ~11.5V, but its still a "9.6V' battery. My 14 cell pack charges to ~21V right off the charger. The EVX never had a prob with it.
