squeeforever
squeeforever's Avatar
10.29.2006, 03:53 PM
Originally Posted by Nick
I see, so if it's around 50k RPM it's too hot?
How do you exceed this RPM then, more volts? I just want something as quick as the 7xl on 6s but more efficent and cooler. I guess I can't achieve that with the same voltage.
Shoot for 35 to 40K. It will be most efficient in this RPM range, thus running cooler and allowing to gear up as well as put less strain on the esc.
