crazyjr
crazyjr's Avatar
10.29.2006, 10:28 PM
I think the BEC is overloading, it will lose signal every once in a while. The way i was told if it overloads it will cut-off and restart, so i think thats whats happening. I'm running a bigger than recomended motor and running the bec at its limit, so i expected it to happen. I will get back to you tomorrow or tuesday at the latest and tell you if the reciever pack helps.
No problem with inexperience, I was there a few months ago, did a lot of reading before i took the plunge, but till you get you're feet wet you don't know as much as you think
