Originally Posted by vette1
If they don't make it how can I use it. And BTW why would they make it if it is no good.
I was assuming you had an Emaxx slipper. Metal gears are much heavier, can cause electrical interference,are noisy,and as mentioned will wear quickly with your setup. Bottom line is there was probably nothing wrong with your original slipper, it was just setup too loose and or didn't have enough friction pegs installed (each hole on the slipper should have a friction peg instead of just a few).
