Hey Mike. From what i see on Starscream's setup, you couldn't run you're single speed plate. The diff is too long, but if FLM can do a tranny case with a drop-out bottom you could get to the diff with a minium of screws
Even on the full size tranny, the bearing holes would need to be adjusted, and a diff won't fit into the width of the single speed. I thought about designing a diff to fit into the single speed SIZED case-the case itself would need to be custom. I may still give it a whirl.
