11.11.2006, 12:16 AM
Originally Posted by neweuser
It's weird. I originally bought this controller to rid heat issues while going lipo cuz i ran the 9920. I may just stick with BK
If you have heat issues with one ESC, you most likely are going to have heat issues with just about all of them. The higher current ones generally have less output resistance so will heat up less under lesser currents, but getting a high current ESC isn't solving the problem. It shouldn't heat up that much. There has to be a reason for the heat; excess drive train drag, slightly incorrect gearing, or inadequate batteries. Even with all of these things set up ideally, running at full throttle for extended times tends to heat them up too.
