I have a duratrax pulse charger and when I charge mt 7 cell IB4200 only one peaks at 8.5 and the other one is at 9.2 and it didnt peak. Whay is this? Do I need a discharger? Like the Deans one.
I have a duratrax intellipeak so its looked at 3.5a. Its weired I cheacked them before I put them on the charger and they were at 9.1 and 9.2, about five minutes later I cheacked them one says it peaked and it was at 8.6 and the other was at 9.1.
So a discharger would help me? How a deans bulb discharger do?
Also I charged them for like an hour and only one peaked like 15min in? The other didnt peak?
Something is wrong there... run them dead and try another charge cycle.
If you have a voltmater, check the voltage of each cell... while resting, charging and discharging if possible to look for bad cells or out-of-balance cells.
What you describe doesn't compute... so keep messin with it....
