MetalMan
MetalMan's Avatar
11.14.2006, 01:44 AM
A guy I work with at the LHS is using the Savage 17mm adapters and the super-large-flange nuts. The adapters fit on similarly to the Maximizers, but they are more like the standard 14mm hexes in composition. I tested out the fit of the 14mm Savage hexes on my Revo axles, and there is some play, but once they nut is tightened down it is pretty much gone. I did also have to do some shimming to allow the Savage hex to fit properly on the axle.
