Cartwheels
11.17.2006, 12:05 AM
Originally Posted by strodedawg
just bought them at the shop, the pinion gear seems way long. the center cvds don not slide all the way on. what did people use to shim the slack? also does anyone know what final drive macII is using on his crt? thnaks for all the help.
Can you grind off some of the shaft on the pinion to make them fit better instead of shimming them.
