crazyjr
crazyjr's Avatar
11.18.2006, 09:20 PM
Originally Posted by glassdoctor
I haved wondered if braiding would make a differnence...
The thing about the glitch we have is that it's typically not under heavy load, like when you are just starting to accelreate hard out of a corner (from close to a standstill) but more when you gently get on the gas.... or are already at partial speed and then pull throttle.
Glassdoctor, What do you have the timing set at? It may be possible that its trying to out-accelerate the motor, I run my timing at the lowest point and have no problems.When i get a front arm for my T4 i will try higher timing and see if i can get mine to do it.
11.18.2006, 10:16 PM
I have my timing set to low and I still get the cogging when doing the reverse-brake-forward thing.
