MetalMan
MetalMan's Avatar
11.20.2006, 01:12 PM
Mike, you're definitely right about the gearing options. I already have an 18t pinion on the input shaft and a 20t pinion on the motor, which is almost the lowest gear ratio I can get on there. I chose the 7XL over the 8XL because I wouldn't really be able to properly gear an 8XL that's running on 5s A123 cells.
Do you happen to have any pictures of your prototypes? I'm interested in what they look like compared to mine. Since you already made one for the stock Revo chassis, I guess that means I truly did rip off your design - but hey, it works :).
