Serum
Serum's Avatar
11.25.2006, 04:15 AM
that .05mm can't hurt that bad..
You can use a gasket between the two halves, i know Ryan used it for his.
VWT4
11.25.2006, 04:29 AM
I don't understand you.
Adding a gasket between the halves won't change the width of the case, only the length will increase.
BTW .05mm metal to metal conntact didn't let me fit the case.
marc993turbo
11.25.2006, 05:45 AM
Hi !
I know what you mean, i tried to install the gear box this night and no, it does not fit.
I am going to buy a milling cutter for my dremel today and cut out the
missing 0,5mm from the braces.
That will not hurt the stability...
Marc.
coolhandcountry
coolhandcountry's Avatar
11.25.2006, 03:01 PM
Originally Posted by marc993turbo
Hi !
Marc.
I think I would use a file first. The dremel is good for larger amounts.
The file is a safer more even cut.
marc993turbo
11.25.2006, 05:49 AM
Hi !
I think you are refering to the transmission half cases that don´t fit quite well because they are too short.
You can either use a gasket or dremel a little bit on the input shaft...
I did the second.
Marc.
