11.26.2006, 04:41 PM
Why is the grub screw coming out? It's no surprise that solder didn't work as you'd have to heat the pinion and screw up enough to have the solder bond well, and even then it won't be the best. Not to mention the solder won't bond to the grub screw. Have you tried loctite? How much "meat" is there for the grub screw to grab into?
