zeropointbug
Z-Pinch racer
zeropointbug's Avatar
12.03.2006, 03:45 PM
no, no it's 700 watts AT THE SHAFT power. And seeing that the motor is only 60% efficient, it takes alot more power to pump into the motor. What im trying to say is that larger motor at the same power as a smaller motor will take it to a higher topspeed, the reason is heat, and continuous power vs. peak power....
