cemetery gates
12.03.2006, 09:46 PM
Originally Posted by Sylvester
Hey guys. Im gonna be converting a hot bodies LSP R. Gonna be using a lehner 1950 7t, 14 cells and UBEC. I will start another thread with pics on build up and such once the truggy comes in. :004:
What do you think would run better on 14 cells? Im leaning towards the MM because of tuning and price. But the quark wont be near its limits - 14 cells is already over the MM's limit. I also have a couple of questions;
-Q1 : How do i disable the MM bec to enable the UBEC?
-Q2 : The kyosho gear mike stocks will fit the center diff, right?
-Q3 : What gearing should i run considering they are HB pro diffs. (46T gear on center diff)
Thanks guys. Should be a great christmas project :)
I am converting a LSP too...
-A1 : look at the wire on the esc that goes to the reciever (can't remember the name) and pull out the red wire
-A2 : yes, the kyosho gear will fit
-A3 : I am going to run 12/46 or 14/46
hope this helps
Bye:018:
