MetalMan
MetalMan's Avatar
12.06.2006, 11:23 PM
Originally Posted by BrianG
That is odd.
Do you plan on removing the stock bus bars and soldering directly?
I think I will solder to the tabs. Right now I have battery bars that have a hole in the center (so the vent isn't covered up), and I also have two different types of copper braid. For side by side, I think I'll use the bars, and for inline, I'll use the braid.
Originally Posted by starscream
$101 shipped for 10 isn't that bad as retail is around $155 for 10.
What does it take to disassemble one of these packs? Are the cells soldered together?
Retail is actually $16.50 for these cells.
It isn't hard to take them apart, but it makes it a lot easier to use a Torx driver bit to take the screws out (Harbor Freight has a 33pc. security bit set for $3). The cells are connected by metal strips through 4 weld joints.
