MetalMan
MetalMan's Avatar
12.10.2006, 12:50 PM
Originally Posted by Sylvester
Im gonna be using the new maxamps 10000mah cells. I am thinking of using 5s1p . As for a balancer a LBA 10. Its gonna go in my bl lsp project running a 1950 7t. Thinking of a quark 125B. For the cutoff what should i set it at? I was thinking 3V. Do you guys think that these new cells should be good for my setup? Also im gonna use the new superbrain 989. My other concerns are what type of balancer plug do the maxamps packs use? I know that i have to get a 5s adaptor for the balancer, but where do i plug in all the wires? When i charge them do i put the deans off the battery into the charger, and than the balancer into the battery? How do i hook the balancer into the charger? thanks guys!
These cells are rated at 150amps continuous, so at 150amps they should be putting out ~3.3-3.4v. Based on that, the LVC should be set at 3.2v minimum, and 3.3v for maximum cell cycles. If you find that the pack cuts out at 3.3v, you could set it down to 3.2v.
You plug the Deans on the battery into a Deans that will need to be put onto the LBA10, and plug the balancer into the charger (the balancer has 4mm plugs that are standard on most higher-end chargers).
