The warriors are a special offer. The MGM has got a build in LVC, and has got more programming features.
Forget the S motor. You need an L or an XL. The XL will give you more torque. With that higher torque, you can gear it with a bigger pinion. The higher the KV, the more powerhungry the motor is. (the quicker your cell are drained)
