neweuser
neweuser's Avatar
12.12.2006, 06:47 PM
Originally Posted by BrianG
Are you putting all your batteries on one side or do you plan to have one on each side?
If you are putting the pack on one side, I'd personally go with a single 5s pack. You won't need a Y adaptor which means less connections and wiring. Really, the only advantage to seperate packs is you have more mounting options...
And with two, you can distribute the weight better. IMO. I would go one 2s and one 3s
