12.16.2006, 04:09 PM
Originally Posted by ReDrUm_Racer
I plugged in each wire to a wire on the battery and tried it, then I switched the white esc wire with another esc wire and tried it, then tried the white esc wire on the last one, none of which worked.
Let me see if I have this straight; you hooked two motor wires directly to the battery?? I guess it doesn't matter at this point.
Does the ESC or motor get hot when it is hooked right?
When you power up the ESC, the motor should make beep and the ESC LEDs should light up. I know there is no beep, but what about the LEDs?
