gorillamaxx
gorillamaxx's Avatar
01.26.2005, 02:32 AM
Awwww... the sand :cool:
Cool truck! Most people go with the low cg chassis to keep all 4 on the floor. If you really want to set-up for wheelies try the standard length rear (longer wheelbase works against it) also try running a hump pack to the rear of the chassis (4 over 5) the straps are designed to go over 2 levels of cells (make sure to lace the strap through the chassis slot for a tight fit) ... and as said before... raise your suspension.
I little bit more mojo doesn't hurt - good luck with the diffs!
