jhautz
jhautz's Avatar
12.18.2006, 11:35 PM
Another Short Update...
A little more testing of the Mamba Max with both the Neu and the Lehner motors. Lets just say the Mamba Max in its current state is not suitable for running a 4 pole motor. IMO
Take a look at this vid clip I put together of my little experiment.
The first part its set up with the Neu 1515 and 5s. Standing start full throttle acceleration. It coggs like crazy 2 times in a row, then with slow aceleration it starts no problem.
2nd part is with a Lehner 1940 in it. You will see no problem at all with a hard full throttle start. Starts right up and just spins the wheels.
Both setups are using the exact same everything including pinion size. Only difference is the motor. This is just a short little clip shot inside to demonstrate what I was seeing. I saw the same thing outside.
http://s66.photobucket.com/albums/h2...v?t=1166497295
Once the Neu started it ran like a champ and the esc ran much cooler than with the Lehner. Thats cuz its only a 1700kv motor vs the Lehner which is 2200kv. If CC can get the start up isssues fixed with the 4 pole motors this can be a really sweet low cost esc. I didn't see any other problems with it. I tried playing with the timing and start power, but nothing really made a difference on how it started with the Neu.
Now I'm kinda stuck. Can't run the Lehner I have cuz its way to hot of a motor and will fry the Mamba in no time. It got really hot running the Lehner in just a matter of 1 minute and I can't run the outrunner that I originally planned to run with it cuz it will not start without a push. So my only real option is the Neu and I'll just have to take care not to start to quickly from a stand still.
I really hope that CC comes out with their software update for this thing pretty soon. If it fixes the cogging problem Im seeing with multi pole motors, then it could be the greatest bargain in brushless. It could be that I'm just spoiled by how smoothly the Quark starts and runs everything. I gotta try that outrunner on the Quark next.
BTW: I know... not the best lighting, but you get the idea.
EDIT: I did se some very minor coggin with the Lener also, but nothing to worry about. Just not as smooth as the Quark. With the proper kv Lehner it could be a really good setup I think.
EDIT 2: And heres a couple pics of the finished setup. Just needs the Rx to be tied down.
to make it...
or break it...
Silent...But Deadly
