GorillaMaxx360
GorillaMaxx360's Avatar
12.19.2006, 08:06 PM
This is the updated list that me and squee have come up with the only difference in the list is the radio preference and the charger(the reason i chose the ice charger -more expensive-is because i have heard lots of problems with the super brains charging the batteries all the way and the ice has more options. the super brain will charge lipo but the ice is more suited for it. This is one is one of those items where if you have the cash you should just buy the more expensive one just to be sure you don't regret the cheaper on, BUT if you would rather save the 60$ you can go with the super brain and it will work) he chose the Nomadio and i chose spektrum spektrum is cheaper than the nomadio and has about the same technology it will not effect performance no matter which radio you use.
Well heres the list i created and squee modified (his opinions are good he is very knowledgeable) with this list it will be a ground up build which means you will not even touch anything on the stock emaxx, because everything on this list is an upgrade from stock. What i would do is race the stock E-Maxx in the stock class and drive it with the one you are building. This will make it fun because you can actually see the performance difference difference between the two. Also you can use it is a back up or spare car if someone else wants to drive/race with you. Heres the list
ULTIMATE MAXX
1.) Unlimited Engineering Racer X suspension pro kit.
2.) Unlimited Engineering Ger 4 servo saver steering assembly
3.) Unlimited Engineering Racer X shock kit
4.) Unlimited Engineering 8mm CVDS with 23mm hex Hubs
5.) External Ubec (on RC monster)
6.) GorillaMaxx Carbon Fiber Chassis
8.) GorillaMaxx Carbon Fiber Chassis Extension
10.) GorillaMaxx G3 Battery Straps
11.) Fast Lane Machine Hybrid Bulk Head Braces
12.) HB Lightning diffs (purchase 2)
13.) RC monster Slipperiential
14.) DUH engineering titanium shock towers (DUH engineering.com)
15.) Revo slipper pressure plate
16.) Revo slipper rebuild kit
17.) Revo 36t spur gear
18.) Proline 23mm standard size Maxx rims
19.) Proline crime fighter standard size tires
20.) Proline medium blend glue
21.) RC Screwz E-Maxx screw kit
22.) ACER Racing E-Maxx Bearing Kit
23.) Lehner 1950/6 high amp motor
24.) Quark 125B brushless controller
25.) Maxx amps (purchase 2) 8000 mah 2 cell lipo batteries
26.) Hitec 5955TG titanium gear servo
27.) Spectrum DX3.0 Radio
28.) RC monster Heat sink
29.) (2) 40mm fans
30.) 70 weight shock oil
31.) Associated black grease
32.) RPM bumper with plastic stock E-Maxx mounts
33.) Durtraxx ice charger
34.) Ofna 12v power supply for charger
35.) 8 AA batteries for radio
36.) misc wrenches like hex wrenches
37.) and a 15t pinion get a higher pinion for more speed (this pinion will get you in the 30s)
38.) Unlimited Engineeting VBS bulk set
39.) Proline power strokes
