Gearing
Shark413
Shark413's Avatar
Gearing - 12.23.2006, 05:59 AM
Regarding the gearing, I have a problem. Using the special motor mount I can only use the 40T spur and 15T pinion. I cannot move the mount any further to the right to adjust for smaller Spurs or pinions. This is because I am using the Revo Mod 1 gears. The mount was originally designed to use the stock 48pitch gears off an E-Maxx. I like the Mod 1's because they are stronger. I guess I could drill and re-tap some new holes to allow me more adjustment, but there isn't much selection in Mod 1 pinions with a 3mm bore hole and the largest spur traxxas makes for the Revo is a 40. I could probably mod a truggy spur to fit, but that would be more work. And on the track I race on, 36 mph top speed and super strong accelleration works out perfectly.
