What did you guys get for X-Mas -
12.25.2006, 02:42 PM
First of what did you guys get. I got the quark 125, the hitec 333 oz steering servo, ofna 17mm hubs, and others. One quick question though what is this lack peice that comes on the quark on the reciever wire. can i cut it off what do i do with it heres a picture thanks. Have a marry Christmas
it feels plastic or something like that should i cut it off, becasue of the way it is wraped is restricts the legnth of the wire by about 2 and 1/2 inches.
Its some kind of thing that reduces glitching or something like that...
I got a DK 4-Pack (top left hand corner), PSP w/ a good bit of accessories, and mostly money...
sweet do you like/ride bmx bikes i have a 2000 dino GT(dino went out of business, but the gt zone is the same thing as the dyno zone) mine is chrome i love bmx bikes.
guys what do you think about this piece should i cut it off can i, i wish to because it is shortening the wire 2 1/2 onces and that is a lot for a 10 inch cord(estimate)
It's a ferrite bead and is meant to block induced interference.
I've had mine off ever since I got the Quark with no negative effects. However, you must make sure your receiver wire is away from any high current source or you may get glitching as Squee said.
To remove it, you'll have to take off the throttle connector. Just use a pin or something to slide each wire out of the connector.After you remove the ferrite bead, put the connector back on; just be sure it's on right. :)
what do you mean by reciever wire the antena wire or the quark rx wire. and if so it has to be next to something in order to work or do you mean it just can not be right next to the motor, batt, or ubec. what should i do to rout the wire and what items(batts, speed control, motor, ect..) should i stay away from thanks.
well to put the thread back on track....I got the following for my truck
feigo 7xl motor w/ 16t pinion
Slipperential
Kyosho STR- body for truck
Misc. rc stuff...diff oil, gonna be getting paint and a revo spur...
Non- rc related....the usual clothes
FFXI 2007 edition for pc
and the family got a PS2 with a few games as well
Slipperential
Non- rc related....the usual clothes FFXI 2007 edition for pc"what is this"
