Aragon
12.30.2006, 11:18 PM
Originally Posted by BigSushi
Only bad thing I can say about them is - what the hell kind of solder do they use to solder the wires to the board? It took forever to get it to melt!
Sounds like you need a larger tip for your iron. Big gauge wiring requires a lot of energy to get it heated up quickly. The only way this happens is by having a large enough tip that can sink its stored energy to what it touches. Bigger (thicker) tip, more stored energy.
12.31.2006, 12:38 AM
The circuit board where the wires enter looks like at least a dual layer board. And, the traces are kinda big and act as a heatsink when you are trying to solder. You have to be careful not to put heat on the solder joint for too long or the heat will travel along the traces and heat up whatever is nearby possibly damaging it. It's better to use a hotter iron for a few seconds than to hold a cooler iron on there longer.
