BigSushi
01.01.2007, 07:56 PM
Ok, update. I re-soldered the connector onto the wire after cleaning it and the wire end. Got it all hooked up and it runs perfect! I will try the 9920 again as I suspect the motor wire was the culprit on it as well.
Goes to show how important good connections are!
01.01.2007, 07:59 PM
Great!
A loose connection can cause all kinds of headaches, not to mention less-than-optimum performance...
