GorillaMaxx360
GorillaMaxx360's Avatar
01.03.2007, 12:44 PM
If i use lipo do i have to run the battery all the way down not below the cutof just for example if the battery lasts 20 minutes (safe to were it hits the 20th minute at the cutoff) and i run it for ten what happens next. after i unplug it can i charge it or do i have to wait and run the other ten minutes out of it later. the quark 125b has a build in low voltavge cutoff right.
Procharged5.0
Procharged5.0's Avatar
01.03.2007, 12:51 PM
Overdischarging damages Li-Po's. Extreme over discharging can lead to a "puffed" pack or worse. That is why the LVC (low voltage cut-off) nneds to be activated on the esc.
GorillaMaxx360
01.03.2007, 01:08 PM
i know but what do i do if i ran the battery half down do i run the other half down or can i charge the battery even thought it still has half left.
GorillaMaxx360
01.03.2007, 01:09 PM
is the activation of the lvc in the quark come already there on the lipo setting or will i have to program it in.
jollyjumper
RC-Monster jumper
jollyjumper's Avatar
01.03.2007, 01:13 PM
driving packs half empty and then charging again is ok.
and yes you'll have to program the lvc.:027:
losi 8ight-t
xray xt8
GorillaMaxx360
01.03.2007, 01:17 PM
will it mes up the batt. or do i just stick it on the charger
jollyjumper
RC-Monster jumper
01.03.2007, 01:21 PM
charge it full again, better leave it with full charge
losi 8ight-t
xray xt8
GorillaMaxx360
01.03.2007, 01:38 PM
so it is safe to charge it when it is not all the way dead but is still usable like half charge. correct.
