Originally Posted by Serum
Sweet. I guess I don't get around enough. I hadn't seen that. Pretty slick BG. :027:
dkros3:
If you do the math and figure the rpms and gear ratio etc... for a emaxx/5700/11.1v for example, you will see how it's a mis-match. The tires would probably spin something like 70mph :005: only if held up off the ground of course. :035:
No biggie though... many ways to skin a cat right? Some have actually run similar setups before, like a Basic 4200 motor with I think 12 cells. That's a pretty crazy setup too.... it worked and was pretty fast but the motor got smoking hot. So even if something "works" it may not work well in a practical way.
