IIRC, the LBA10 cuts off charging at 4.25v/cell. So if the balancer is cutting your charge early, either your balancer is not calibrated quite right, or the charger is trying to do a CV charge a little higher than 4.2v/cell. If you have a volt meter around, I'd measure one of the cells as it's charging to see what the voltage really is.
