MetalMan
MetalMan's Avatar
01.08.2007, 12:07 AM
I would have no idea. I've never burned up a motor. My guess is that the only way to do that would be to run an ESC with high current capabilities with a motor that is smaller and doesn't require too much current. Then, you could overgear the motor and the ESC might not heat up too much, but the motor would get very hot. So basically, it depends on some factors.
