ubec?
revopqrs
uhhh-huh!
revopqrs's Avatar
ubec? - 01.09.2007, 04:11 PM
so i just received mine, i installed it correctly.... but the speed controller doesnt have power now? i clipped the red wire like it said, but it seems to have taken out the sc?:035:
am i missing something here?
i got this one...
http://www.helidirect.com/product_in...oducts_id=1158
Serum
Serum's Avatar
01.09.2007, 04:24 PM
Some speedcontrollers need the red wire, it provides them power. what speedo have you got? i know the BK manual explicitly tells you not to loose the red wire with the warrior controllers. With the micro's you need to unhook the red wire though.
Serum
Serum's Avatar
Thread moved to general electric.
revopqrs
uhhh-huh!
revopqrs's Avatar
01.09.2007, 04:26 PM
thanks for moving...
im using the stock maxx evx controller right now.
Serum
Serum's Avatar
01.09.2007, 04:30 PM
Okay.. don't know too much about that thing.. Let's hope Artur finds this thread (griffinru) i think he has got an answer for you.
crazyjr
crazyjr's Avatar
01.09.2007, 05:11 PM
Which esc was it?
Procharged5.0
Procharged5.0's Avatar
01.09.2007, 05:19 PM
Traxxas EVX
crazyjr
crazyjr's Avatar
01.09.2007, 05:27 PM
he was talking Ubec, so i assumed it was brushless. All he should need to do is turn off the esc and run it with the Ubec, all the switch does is control the bec and with that off it will run with any input source (UBEC or reciever pack). this is standard on any Novak based setup( not sure about others. Put the middle wire back in and leave the switch off and it will work fine with the ubec
revopqrs
uhhh-huh!
revopqrs's Avatar
01.09.2007, 05:39 PM
yup crazy... you nailed it!!:028: with the switch off it works, thanks for the help.:030:
crazyjr
crazyjr's Avatar
01.09.2007, 05:40 PM
Cool, Glad it worked. Thats how i setup the esc when i don't have a battery charged enough to power the system
