Sylvester
Sylvester's Avatar
01.10.2007, 05:19 PM
Thanks Squee!
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
cemetery gates
01.10.2007, 05:28 PM
Originally Posted by squeeforever
http://www.lstshop.co.uk/catalog/ind...7ae9b7702ef386
http://www.truggyracers.com/forum/in...p?showtopic=45
Let me know if you need the 8mm axle conversion kit parts...
Heres the parts for the upper arm mod:
22* hubs
buggy arms
upper arm pins
balls for rod ends
you can use these (the things on the far left and right sides, they should have came with your truck) or I would recommend these instead.
I would also go with this to eliminate some flex.
Thanks!
Bye:018:
squeeforever
squeeforever's Avatar
01.10.2007, 07:49 PM
No problem. I can give you more info, but the most useful thing is the link to the truggyracers forum. That list has pretty much everything you can do to your LSP.
