Mike.L
Mike.L's Avatar
01.11.2007, 09:41 AM
you could try deans wire. the wire you use is it noodle? deans uses tiny little strands and can carry high amperage and what not...
also, have you cheked for any butcherd wires that are visible?
and the wires connection to your esc and motor isnt long?
  Send a message via MSN to Mike.L
01.11.2007, 12:25 PM
You could also be losing power at the connectors if they aren't hooking up perfectly or are dirty. The heat generated at the connectors then travels along the wire.
jhautz
jhautz's Avatar
01.11.2007, 08:04 PM
I agree... Make sure your connections are good. What kind of connector are you using? Deans... 3.5mm gold bullet? What wire is it? the motor wire or the battery wire?
Also mentioned above is wire length. If you are still getting heat shorten it as much as you can.
I would think the 11 gauge would be plenty. I use 12 or 13 on most stuff and dont have any issues.
to make it...
or break it...
Silent...But Deadly
