MetalMan
MetalMan's Avatar
01.17.2007, 02:39 AM
It depends on how you use the other chargers. That power supply can handle 240watts. If you assum 85% charger efficiency, that means that all of the chargers combined can put out 204watts. If you're charging three 4s packs (16.8v each), that means you can charge at a combined 12.14amps, or 4.05amps per charger.
