01.18.2007, 05:59 PM
Originally Posted by turbo4
From what I remember its normally from a dead stop or very near it then goosing the throttle. I suppose it could be the lvc jumping in under heavy load, but it seems to have happened at a fresh charge a time or two.
You could lower the cutoff value, or remove/disable the LVC temporarily to see if that is the problem.
