Sylvester
Sylvester's Avatar
01.22.2007, 07:55 PM
Welcome to the forums!
Not sure on the body. The lightning 2 pro looks like a great candidate for BL!
The 8xl will be more than enough to power the buggy. A Mamba maxx is perfect on 12 cells with a UBEC. I would reccomend a fan on it. The MM has great brakes, so no problems there.
Id try to use a Plastic spur gear for the center diff, and a 5mm bore pinion off mike.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
Gearing
nativepaul
nativepaul's Avatar
Gearing - 01.23.2007, 09:57 AM
Glad the stuff I decribed will work well, at those budget prices hopefully it wont be too long before I can afford one. i was half expecting to hear that all that stuff wasnt suitable and I'd have to spend a lot more than that to make it work reliably.
Any idea how to gear the 8xl in a lightning 2 pro? ie what size spur and pinion, should I wait till I get the buggy then count the teeth and get direct replacements? or will I need to use a different size spur and pinion for a higher/lower than stock ratio in my set up?
