Procharged5.0
Procharged5.0's Avatar
01.25.2007, 01:42 AM
Yes & No MM.
The holes do line up with the 3.3 slipper pressure plate and can be drilled to fit. The center hole however is not 10mm and the size must be just right for a mild interference fit for the 5x11 bearing. It must also be on center to prevent excessive run-out which would make setting pinion/spur mesh a nightmare.
