Serum
Serum's Avatar
03.02.2007, 02:58 AM
Good point, we don't need a superconductive controller to get to a 100 percent total efficiency that way..
Serum
Serum's Avatar
03.02.2007, 12:48 PM
But here is the question; you say lehner date is calculated? because this is not the case, it's real measured data.
GriffinRU
03.02.2007, 01:04 PM
I was reffering to this document
Serum
Serum's Avatar
03.02.2007, 01:47 PM
I don't know artur.
They claim it's measured. I thought dafni told it was done with a prop. why is the current changing, as well as the voltage? It would be easier of it was used as a set parameter.
And can you explain the large dip in efficiency with this one;
http://www.lehner-motoren.com/diagra....s26_liste.txt
GriffinRU
03.02.2007, 02:10 PM
I don't know artur.
Because with RPM BackEMF comes to play and in addition to active resistance come reactive from inductance (capacity plays as well). Then you can add core hysteresis and eddy currents. Not even touching ESC efficiency which you use to dyno test motor.
When you add timing to equation it becomes tricky, in general with timing set at zero (my program default, adjustable in future) efficiency of the motor has linear relation factor (in calculation) with motor RPM, when you change timing you pushing this relation to be less linear across entire RPM but to be higher in the mostly used range. That is why you see a big dip in efficiency when you get out of tuned efficiency envelope.
Serum
Serum's Avatar
03.02.2007, 04:23 PM
Nice theory, but since they also included the Delta and the Wye windings, it would make the calculations far more complicated than you are describing. PLUS they DO use timing in their numbers. This STILL doesn't explain why they don't use a set number of voltage. (this is variable as well) I know one reason why this number would be variable, but it simple makes no sense to 'assume' a resistance of a battery, since this is variable as well..
And now we are getting deeper into it; why are brushless motorcans not made from plastic? aluminum is magnetic active when there is a magnetic rotor is turning in it. (even a U, or an unclosed piece of aluminum has this 'problem') I think plastic motorcans would help making a brushless motor even more efficient.
but here is the big q;
What makes you think/presume they use calculated data instead of measured? agai'n; Daf mentioned they use a propellor to measure the power; the other numbers that you call measured is static data.
GriffinRU
03.02.2007, 04:50 PM
Delta or Wye is covered by the same constants. Same motor with Delta wiring will have different constants if you wire it as Wye.
Can material will make big difference if it would be close to magnetic field, for current configurations we talking about fractions of %, which still loss but so small.
I am not following you about constant V, You can dyno motor at constant power, but then it would be not easy to read data. And actually there are cases when you would like to test motor under constant power, but you talking about voltage.
As for Q, click on any cell in calculated area and then check in entry field, you will see formula on how particular cell data was obtained.
Serum
Serum's Avatar
03.02.2007, 05:01 PM
Heck, now i see.
Okay, that's calculated for sure.
I never paid close attention to the excel sheets..
Dafni
Dafni's Avatar
03.02.2007, 05:13 PM
Rene, I said they use props to get a loaded KV value, nothing else.
Serum
Serum's Avatar
03.03.2007, 03:05 AM
Okay, thanks for clarifying Daf.
