gears
tonka truck
tonka truck's Avatar
gears - 06.19.2005, 06:43 PM
Mike: the three speed gears are stripping. On the inside there is a bump which the clutch engages. It was this bump that wore. Even new out of the box it shredded the gears and so was the mesh was factory set. I was thinking that the flywheel clutch on the engine may have smething to do with it.
For conversion, would you be able to supply me with the kyosho parts?
Dafni: I was looking at keeping the truck stock, except to get the spur, pinion gear setup and drill holes to suit on the exisitng chassis plate (save a few $$$)
For performance, looking to use x2 8.4 NiMh (GP3300) packs (16.8v in total). What motor will achieve a good balance b/w run time and accerelation/ speed (similar to nitro)
