But green locktight sounds like it would be good also.
NNNNNNNNNNNOOOOOO
Do not use green Loctite. All it will lock is the bearing, the bearing will then break apart assuming the ESC doesnt Fry, and then the rotor hits the windings. We tried it in a pinch on 3 motors, and had a 100% failure rate within 2 runs.
