pinolelst
02.05.2007, 05:52 PM
Originally Posted by Bomb-Proof
NNNNNNNNNNNOOOOOO
Do not use green Loctite. All it will lock is the bearing, the bearing will then break apart assuming the ESC doesnt Fry, and then the rotor hits the windings. We tried it in a pinch on 3 motors, and had a 100% failure rate within 2 runs.
Sorry if I misunderstood the question ...you use the green loc-tite to secure the endbells...it should never be anywhere near the bearings as it has great wicking properties
pinolelst
