Dafni
Dafni's Avatar
06.20.2005, 05:24 PM
Hey, I'll try to help you.
-Soldering deans is not as hard as it seems, you should give it another try. (plus, I would solder the powerpoles, too)
Just tin the bar on the dean, as well as the wire. A healty blob of tin on each part. Then press them together (use a third hand, washing-line clip, or pliers with rubberband will do) and melt the blobs together. Practice helps, keep trying!
-If you don't like the pre-tinning on your controller wires, just cut it off. Easy.
-Hard wireing or plugging, both have their advantages. I like my stuff solid, but will try these gold plugs for test purposes. Once I find a good setup, I will hardwire it. Removes one possibility for trouble, always a good thing IMHO
-Switch at the UBEC, hmm, I include a separate plug on my batts for the UBEC. One for the ESC (dean), and one for the UBEC (smaller BEC-style plug).
Hope this helps. Excuse my english, I try my best.
