glassdoctor
TEAM FUSION
glassdoctor's Avatar
02.17.2007, 12:15 AM
Man that's not good... I would check over all the connectors.. maybe resolder anything not factory.
What happens if you reboot without unplugging the black wire? Does it only work again if you unplug/replug this wire?
I wonder if the caps are fried or something is wrong with the motor.
When you plug in the battery, is there a spark? There should be. If there is no spark, the caps are shot.
I don't know man... I have never seen anything like this with the stock setup.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
