02.17.2007, 12:59 AM
Wow! I never thought I'd see you stray away from your sensored setups! Welcome to the dark(er) side. :)
Maybe I'm a little paranoid, but a 6 turn motor on the MM seems a little on the low side. You'll probably need a fan to keep it cool. Just my $0.02...
I'm using Spektrum and Mike's UBEC in my Revo and have no glitching trouble at all. Whenever I use a switching BEC, I like to add at least a 1,000uf 10v cap to the free AUX receiver slot - helps filter any "noise" and provides a little oomph for the relatively high current pulses the steering servo sometimes pulls. Also, keep the BEC away from the antenna.
