Not trying ot bust on you... but I tried to make a thread to post pics etc of my stuff so it's not all over the forum. ;)
I think I need to work on a website and just link to that... does that work good for anyone? I have seen a few guys do that but I tcan't think of too many guys here that have websites or pages with their stuff.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
new avatar ;) this is the car I wanted back in the day... I had the original Ultima and i thought the Optima was sweet but I never got one.
Ah yes, I remember the good ol days of the Optima. That was my first RC (I believe it was 1987). My buddy had the Assoc RC10 but I wanted something 4wd so I got the Optima. Too bad we didn't have brushless back then...
Ha Ha
:) from you first post "Maybe others can do the same" i thought its a thread for others to post pics so the forum is not full of tons of pics threads :)
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
new pics of 8ight with 1512 (other pic of it had the 1515)... and my old XX4 with MM 7700 and maxamps lipos
Big brother little brother Losis ain't it cute?
Awesome!
I am currently doing a conversion for a 777. Can I ask where you got your pinion gear from? I am having a hard time finding the correct pitch.
Thanks,
Steve
also you will find some made by Century, the r/c helicopter company.
Thanks.
I am using a Mamba 5700 motor which has a 1/8 inch diamiter shaft. It appears that all they have availible that works with the metal spur gear is 5mm bore. Do you know of an adapter or sleeve to make the 5mm bore pinons work with the 1/8 inch shaft?
Thanks.
Yeah.. I think he has had some 1/8" bore mod1 gears before...
EDIT: woah... you are using a MM5700 in a 777? That motor is way too hot (too high kv) for a 1/8 buggy and it's undersized too. It will run but it will get very hot.
You can try it but watch the temps and see what happens... I think you will be picking up a new motor very soon. And it will have a 5mm shaft... ;)
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
It will be running on 11.1v li-po. If I gear it very low, do you think I will still have problems?
