XXX-T/Mamba 5700/3s Lipo Speed Run Results
BoysToys
XXX-T/Mamba 5700/3s Lipo Speed Run Results - 02.18.2007, 06:22 PM
I made a couple of speed passes today with my XXX-T/Mamba 5700/3s2p lipo. Highest Speed 57.3mph, geared 19/86, this was my biggest pinion I have. I am sure that there is more in it but I will have to get a couple of larger pinions and find a longer street to test in. This thing is just CRAZY!
jnev
jnev's Avatar
02.18.2007, 08:39 PM
This is also in a stadium truck, and form the loks of it, has some pretty beefy tires adding quite a bit of weight. Imagien it in a carbon fiber street car? lol It'll be hittign over 65mph. That is still awesome none-the-less. Is the battery you are using from Max Amps?
BoysToys
02.19.2007, 03:29 AM
Yes the battery is a MaxAmps 3s2p 6000mah pack. The tires are Masher 2ks and agreeably not the best for a speed run. I just wanted to see what I it would do. I know that there is a lot left in it even in this truck. I could probably pull a 22-23t pinion and mess with the settings on the Mamba to really max it out. I may attempt to get it over 60mph and call it quits.
glassdoctor
TEAM FUSION
glassdoctor's Avatar
02.19.2007, 10:48 AM
Good to see someone with a setup like this... that's NOT using a rusty :005:
But you do have the big tires which seems all too common :005:
Just teasing... really you need to grab a couple bigger pinions and get that thing over 60! :004:
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
jnev
jnev's Avatar
02.19.2007, 02:51 PM
What kind of run times are you getting with this set up?
hyperasus
hyperasus's Avatar
02.19.2007, 05:08 PM
Did you have to use the tape trick on the tires to keep them from flying off the rims?
BoysToys
02.19.2007, 05:20 PM
I get about 30-35 min of run time geared 14/86. I normally give it a break after about 20 min and let everything cool down. I did use the tape trick before mounting the tires to the wheels. I ran a strip of Gorilla tape around the inside and it does a good job of keeping them from ballooning. I am sure that this setup would be much faster in a carbon fiber street car. But then I would not be able to jump it off everything and ride block long wheelies.
